Hi guys, my 1999 mexican beetle was lowered by the previous owner and I would like to take it back to stock height or get it back to its original height when it left the factory and I'm trying to do the spring plate adjustment and need to know what's the stock angle for these bugs. Do I need to have the car level front and back or just by using the protractor and taking the actual angles from the door sills is enough?
Also, how is my bug supposed to be lowered up front, is there any other way other than drop spindles? Want to make sure before I order a new set of stock height spindles.
Btw, my bug was a little bit lower on the drivers side than the passenger side, about 3/4 of an inch or 1.905cm. Would this be bad adjustment or what?
Thanks in advance.
