This is my first post. I've been using the site for the past month to fix small details on my 1600i and I believe found an error I would like to share or get some insight.
Section 14/4 (Instrument Cluster):
Line 31 states that the common ground for the light bulbs on the cluster goes bridged to terminal 86 from Digifant Relay AND terminal 30 from Fuel Pump Relay.
THIS WILL RESULT IN A SHORT CIRCUIT
Correct wiring for relays is stated at Section 10/8.
