Voltage regulator
BeitragVerfasst: So 22. Feb 2015, 04:33
von wellcraft
Hi guys, I need to replace the voltage regulator on my 1999 Mexican beetle. The part number for my alternator is Bosch 9-120-080-061 and I'm not sure whats the part number for the voltage regulator and haven't been able to find it.
Thanks in advance for any help.
Re: Voltage regulator
BeitragVerfasst: So 22. Feb 2015, 08:35
Hy wellcraft,
9121080281 partnumber Brushes
9190087003 partnumber regulator
see Hoffmann-speedster.com Number : 020-1269 Spannungsregler,Drehstrom. for AL 82
BeitragVerfasst: So 22. Feb 2015, 14:56
von wellcraft
Thank you Hubertus, so this is an Al82 alternator, I was trying to figure out that and I asked before but nobody was able to tell me.
I'll go ahead and order one and do the modification I found on the technical section so I don't have to remove the alternator as it is so time consuming.
Thanks again.
