Mexican Klemmutter
BeitragVerfasst: So 15. Mär 2015, 19:07
von mbeamish
http://www.ebay.co.uk/itm/VW-Front-Axle ... 1325513261
Hello kann ich diese verwenden auf meinem 2003 mexican 1600i Kafer bitte
Hello my german is not good . Can i use the german style clamp nuts on my 2003 mexican beetle? Will the grease caps fit etc
Re: Mexican Klemmutter
BeitragVerfasst: So 15. Mär 2015, 19:39
von spargelix
Yes, it is possible to mount the "german style" clamp nuts...
BUT:
You also have to mount the specially formed trust washer/guard plate and also change the grease caps to the old ones, as the clamp nut needs a little more space in the hub. The original cap fits IN the hub, the old one fits OVER the hub.
Setting the bearing clearence will get much more comfortable and precise, so it's worth the afford.
Greetings from spargelix
Edit:
guard plate:
http://www.csp-shop.de/cgi-bin/cshop/fr ... ort=0&all=
clamp nut:
grease cup:
BeitragVerfasst: So 15. Mär 2015, 20:09
von mbeamish
Danke Mike
