Which Camshaft for ACD Engine
Beitragvon paullanzarotti » So 14. Feb 2016, 23:58
Hi,
I am rebuilding my 1600i but I don't know what cam to use.
Does anyone know the part number for the ACD camshaft?
Thanks
P
paullanzarotti
Re: Which Camshaft for ACD Engine
Beitragvon KaBe » Mo 15. Feb 2016, 08:01
schau mal bei VW Classicparts im Teilekatalog unter "service". Viele Grüße. KaBe
Beitragvon paullanzarotti » Mo 15. Feb 2016, 08:44
Hi
I checked the Classic Parts site and there are 3 different parts called "Camshaft"
113 109 019 G - 69.95 euros
113 109 023 G - 169.00 euros
113 109 027 G - 69.95 euros
They all say they are for the 1600i.
I imagine they all have a slightly different size timing gear but why are the prices different?
paullanzarotti
Beitragvon hrtpower » Mo 15. Feb 2016, 18:47
part Numers Camshaft ACD:
BAA109021 Standart +- 0 Original ACD Mexico/Brasil
025109021 Standart +-0 Original WBX 1,9 l DF ( I could be the same as the ACD)
025109021B Standart +-0 Original WBX 2,1l DJ, MV (For tuning, a 275 degree camshaft with 8.3 mm stroke, which also works with hydraulic tappets)
hrtpower
Beitragvon paullanzarotti » Mo 15. Feb 2016, 19:13
Thank you for this.
So the 025109021B Standard +-0 Original WBX 2,1l DJ, MV will work with Hydraulics and Manfreds 1804 chip?
paullanzarotti
Beitragvon hrtpower » Mo 15. Feb 2016, 21:27
I think so. The next Engine with this compnents is on work, but not done yet. And for an 1835i Manfred named the chip 1805.
hrtpower
Beitragvon paullanzarotti » Mi 17. Feb 2016, 23:41
Ok - thanks you very much for the advice (Your English is excellent too!)
I am going to build this:
90.5 Cylinders - 1776
32/35mm Valves
Hydraulic Tappets
Camshaft 025109021B Standard +-0 Original WBX 2,1l DJ, MV (For tuning, a 275 degree camshaft with 8.3 mm stroke, which also works with hydraulic tappets)
Balanced
Manfred 1804X Chip
I am hoping Manfred can confirm this configuration will work with 1804X chip and then I will start work :)
paullanzarotti
Beitragvon paullanzarotti » Do 18. Feb 2016, 09:39
This camshaft could work too:http://www.ahnendorp.com/VW-Wasserboxer-Motorenteile-und-Bearbeitungen/Nockenwellen-und-Zubehoer-67/Schleicher-Nockenwelle-VW-Wasserboxer-292-Grad.html
paullanzarotti
