Cylinder temperature sender Calibration settings
Mi 7. Jun 2017, 20:02
von paullanzarotti
Does anyone know what the calibration settings for the stock Mexican 1600i cylinder head temperature sensor should be? (Part: 113 906 161)
Re: Cylinder temperature sender Calibration settings
Mi 7. Jun 2017, 21:18
von zumsel
Hello,
I don't have knowledge about these calibration settings.
But the sensor is a passive element. After replacement the new one should have the same parameters like the old one, if it's the same sparepart.
By the way: Both temperature sensors have the same characteristic curve. E.g. cold engine: both sensors shall have the same resistance.
Greetings Zumsel
Mi 7. Jun 2017, 22:46
von paullanzarotti
Thank you for the reply however, I am using Megasquirt ECU so there are no "stock" settings.
