Scangauge by linear logistic
Beitragvon lollo66 » Do 21. Jul 2011, 14:38
I found this product on the net:
http://www.scangauge.com/
what do you think of this :?:
Can it work properly on our 1600i :?:
Italian 1600i
lollo66
Re: Scangauge by linear logistic
Beitragvon Manfred » Do 21. Jul 2011, 17:50
Hello Lorenzo,
their parts look realy nice.
But as nearly all products in this market, they only accept OBDII protocol. But the 1600i ECU uses an older protocol.
Scangouge writes at their homepage:
http://www.scangauge.com/category/support/faqs/compatibility-faq/
Will the ScanGaugeII work on my vehicle that was purchased outside of the US and Canada?
The ScanGauge requires the vehicle to be either OBDII or EOBD compatible. In the US and Canada, cars and light trucks were required to be OBDII compatible starting in 1996. In Europe, EOBD was phased in between 2002 and 2004.
So i think there is no way to use it with the 1600i ECU.
By the way, the 1600i has no electrical signal for the driven distance and also no output of the amount of used gas.
cheers
Mitglieder in diesem Forum: 0 Mitglieder und 126 Gäste
