pushrod tubes???
pushrod tubes???
Beitragvon jasonrobert » Di 26. Jul 2011, 07:05
has anyone on here fitted adjustable pushrod tubes to their 1600i? I am talking about the type with two nuts and one half is gold and the other half is blue.
I have just put some on mine and either way round the pushrods touch the side of the tube( the gold bit touches because it is smaller diameter)? has anyone else come across this?
If so what did you do, or what alternatives did you fit?
Cheers, Jason.
jasonrobert
Re: pushrod tubes???
Beitragvon Red1600i » Di 26. Jul 2011, 19:03
Hi Jason,
every standard pushrod tube of a 1600ccm type should fit into a 1600i. The golden/blue ones i have seen, but never used... i expected exacly the same problem.
I used up to now stainless steel pushrod tubes from CSP for the standard motor.
Also a 2-piece version with a spring for the bigger 1800i engine also from CSP. But this version needs some rework on the cylinder heads. And they are necessary for 1.3 rockers.
Martin
Mitglieder in diesem Forum: 0 Mitglieder und 110 Gäste
