Hi;
Really apreciate your advice, for my 1600i to 1776cc.........Make a sense install a Mexican Vw Golf 1800cc telmic digifant (25 pines) and injectors?
Advantages?
Best regards.
Juan Pablo
juanpablo1969 hat geschrieben:Thank you Manfred; I can apreciate that, then is not better install stock 1600i digifant with 1800cc vw Golf injectors?
Is a good idea?...I can add cc´s only (1776cc), same CR, Cam, valves, etc.
or any recommendation?
I need your advice please.
Manfred hat geschrieben:Hello Juan Pablo,
no, thats makes no sense.
The maps of these ECUs are very different from the 1600i ones.
The Golf ECU use the temperature of the cooling water, the 1600i the cylinderhead temperature. These values are also complet different.
For ex. i show you some maps
First the org. 1600i injection map:
Second the injection map of a 1,8l Mexican Golf ECU
Third the ingniton map of the 1600i
And at least the ignition map of the Mex. Golf ECU
You see the differences ?
Even if it would work on an 1600i engine, you never would be satisfied.
Cheers
Mitglieder in diesem Forum: 0 Mitglieder und 61 Gäste
