Hi everybody,
My 1600i (1997) show two strange problems; Sometimes when i turn contact key, the tachometer needle jump to the top along with a vaccum sound at the engine bay (last owner installed a tach directly to the ignition coil)....
when I start the engine (cold), revs up to 1500 RPM first, then as it gets temperture RPMs down to 850 (wich i think it's normal), but sometimes cold starting is all the way different, first at 850 RPMs (no "choke" effect), runs very "uneven", sometimes stop running along with a strong gasoline smell at exhaust.....
Any advice or approach ??
Best regards from Chile !!!
