Trigifant by trijekt !!!
Beitragvon lollo66 » Mi 29. Aug 2012, 12:41
Hello,
surfing on internet I found this information:
http://www.trijekt.de/Motormanagement_f ... 06-53.html
http://www.trijekt.de/-73.html
Do you know?
Can this replace the digifant of ACD engine ? may offer advantages?
Italian 1600i
lollo66
Re: Trigifant by trijekt !!!
Beitragvon Red1600i » Mi 29. Aug 2012, 13:42
Yes, it works.
I'm driving the older Trijekt Plus already since 2004... :lol:
The new Trigifant makes adaption much easier, just plug&play.
Beitragvon lollo66 » Mi 29. Aug 2012, 16:01
Red1600i hat geschrieben:Yes, it works.
I have a stock ADC engine 1600i (whit Manfred chiptuning), what are the advantages?
Italian 1600i
lollo66
Beitragvon Red1600i » Mi 29. Aug 2012, 17:12
Free programming and diagnostics, using a laptop you can see every parameter.
Beitragvon lollo66 » Do 30. Aug 2012, 08:29
Red1600i hat geschrieben:Free programming and diagnostics, using a laptop you can see every parameter.
Can i increase the power of my engine (stock ADC) using the trigifant :?:
Need to replace parts of the injection system for this :?:
I'm not an electronics expert and I would like some advice to improve my engine. :roll:
Italian 1600i
lollo66
Beitragvon Red1600i » Do 30. Aug 2012, 10:50
lollo66 hat geschrieben:
Yes. Without changing hardware around 65hp. With changing hardware... hmmm, unlimited. My 1800i has 115hp, my M102T B7 Turbo 800hp...
No. But you can change everything.
Hmmm, life is learning a lifetime...
Beitragvon lollo66 » Do 30. Aug 2012, 12:06
Red1600i, you're very kind for the information.
For about 70hp and in compliance with Euro 2 emission, what hardware should I change?
I am interested in Trigifant and how this works, can you help me?
Italian 1600i
lollo66
Beitragvon aviator » Do 30. Aug 2012, 18:35
As Red1600i said, you can get something like 65HP without harware changes. If you "only" want 70HP you could go for 90.5mm pistons and cylinders giving you 1776cc and about 72 HP. With a different camshaft and larger valves maybe 80HP. With new throttle bodies (like dual carbs) you can get 100+HP.
aviator
