A Brazilian Kombi Welcome & Help
Beitragvon sparkysteve » Mi 24. Feb 2016, 14:41
I have a Brazilian Kombi T2c (2004 Air-cooled). I know it's Brazilian and a Bus BUT i's still from South America!
I know this is a forum for a Mexican Beetle BUT I was wondering if I could ask for some help?
I am like you and struggle with the lack of information from vehicles from VW Brazil or VW Mexico and have an issue with my fuel injection Flat 4.
The Kombi uses a MP9 ECU but its a slightly more advanced version of the Digifant.
I am having trouble with the following Fault code:
00533 - Idle Speed Regulation
10-00 - Adaptation Limit Not Reached
It is similar to the Beetle code as well.
I am unable to perform basic settings as this fault code is always comes back even after a clear (If I clear at higher RPM it clears and does not come back for some time but not enough)
Do you have any ideas how to do Basic settings with such a fault code?
Do you know any other causes of this code?
I have tried and found NO Vacuum leaks. All sensors (MAP etc) are correct. ISCV is working but rpms drop a little Before coming to an idle.
Thanks
Steve
sparkysteve
Re: A Brazilian Kombi Welcome & Help
Beitragvon RedRat » Do 25. Feb 2016, 10:27
Hi Steve,
did you reset the errors ? I had most of the times errors due to lack of batterypower. Most of the errors disapperead after beeing cleared once.
Regards,
Alex
RedRat
Beitragvon sparkysteve » Do 25. Feb 2016, 13:41
RedRat hat geschrieben:Hi Steve,
Regards,
Alex
Hi Alex, Thanks for your reply.
Yes I have reset the fault codes in VCDS. They clear BUT it then comes straight back at idle. If I hold revs rpm to about 1200 (Spec is 850-950) it clears and stays clear.
If I then try to do a basic setting it does not work as idle rpm is too high. If I let it idle the fault code returns then I cannot do basic setting as fault code is present. Catch 22.
Battery voltage is fine. Its just will not clear at idle.
Steve
sparkysteve
